09-22-2024 02:37 PM
I can't get the 6 digit code off my Nest doorbell camera due to it being installed. Is there another way to get the 6 digit code without uninstall of doorbell camera ?
09-25-2024 07:59 AM
The 6-character alphanumeric setup code is printed on the back of the 2nd gen Google Nest Doorbell--above or below the QR code; it is NOT printed anywhere on the box in which the doorbell comes.
Besides being printed on the back of the doorbell, the QR code is also printed on the Quick Start Guide that comes with the doorbell.
So, if you do not have the Quick Start Guide, you will have to dismount your doorbell in order to either scan the QR code or to read and enter the 6-character setup code.
09-23-2024 06:49 AM
You need either the QR code or the 6-character alphanumeric Setup Code in order to install or reinstall a Google Nest doorbell or camera.
For the 2nd gen Google Nest Doorbell, the QR code is also printed on the front of the Quick Start Guide.
(We write down the 6-character Setup Codes for our cameras and doorbells.)
09-25-2024 07:54 AM
My issue is the Doorbell camera is installed and I can't find the 6 digit code anywhere on the box it came in. Will I have to take out the camera from the door bell get the code and then Reinstall or is there another way?
09-25-2024 07:59 AM
