03-12-2022 06:20 AM
I am considering purchasing the nest doorbell however existing doorbell is only 3 feet from ground. Will it work at this height? Although it is battery version I prefer to use wired and will be unable to extend wires to suggested 4 feet height
03-12-2022 10:22 AM
Three feet is a bit low. The recommended height is 4 feet. There is no reason it won't function though. However, when someone is standing close to your door or the doorbell you may not see their face or head. You might also consider a custom "shim" using a washer at the bottom to point it up if it's aim is too low. It also comes with some rubbery spacers that you may be able to use to adjust the aim.
Is there some concern you have in particular?
Recommended height:
03-19-2022 10:21 PM
Huge shoutout to @sporfrog. Appreciate the help. As an added tip, you can check this article on Tips for camera placement for more info.
Steve
03-22-2022 10:49 PM
It's me again, I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
03-26-2022 03:47 PM
Just checking in to see if you still need help with this. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Steve
