12-21-2021 10:30 AM
The issue started as you had to hold the button a little longer to ring the doorbell. Then the house doorbell stop ringing, next the Hub started missing alerts. Now not even my phone is getting a notification when the doorbell is rung. I've check the wifi and all connections no issues. Even put the Nest Hello on a adapter for power doorbell still won't ring.
12-21-2021 03:56 PM
Do a FULL power cycle of your home. So this would be your router, nest doorbell, all smart speakers and displays, your phone, everything. If the problem persists after everything has had a chance to reboot then it could be an issue with the doorbell itself, but I suspect the full reset will get things moving again.
03-15-2022 11:12 AM
P.S Thanks for your help @Ashepherdson!
03-16-2022 11:14 AM
Hey Folks.
