Nest Doorbell won't connect
Skaner
Let's try this again.
I've been trying to install my Nest Hello and always get errors NC022 or NC023. The doorbell is about 2 feet from the hub so connectivity shouldn't be an issue. I've never had issues with other Nest products, some of them are 30 feet away and connect fine.
Thanks
Skaner
Hi, yes I just can't get it. I've also tried resetting the doorbell to factory settings but that won't work or at least doesn't impact the installation process.
Just checking in to see if you still need assistance with this issue.
Hey Folks.
