Nest Hard Wired Vertical Adjustment
JFS1001
Is there set screw or another mechanism that will hold my Nest hard wired camera in place so that I can can raise it upward?
2 REPLIES 2
SoriaD_
Hello @JFS1001
Thanks for reaching out to our Nest Community about your wired camera. I apologize for all the inconvenience; don't worry, I'm here to help you with that.
All you need to install this camera is included with the device. If necessary, you need to drill pilot holes. Use a 7/64 in (3 mm) bit or a 1/4 in (6 mm) bit if you’re using the wall anchors.
Unfortunately, we do not have these precise parts available on the Google Store.
Keep us posted if you have another question. I'm happy to assist you.
Douglas.
JFS1001
I am looking for a way to physically adjust the camera view vertically upward. Does the NEST cam have that capability?
