Nest Hello Wall Plate Replacement
Snowbird20
Where can I get a wall plate for my Nest Hello Doorbell.  I broke one of the tabs during installation
Ashepherdson
Gold Product Expert
Gold Product Expert
While you can try the google Store support team, https://support.google.com/store/gethelp, if they are unable to help there are also third party products that may work for you ,
https://www.amazon.ca/Wasserstein-Vertical-Mount-Compatible-Doorbell/dp/B07WRRF24F/ref=asc_df_B07WRR...
I wonder if you are also able to contact Google Nest support via the "Contact us" link at the bottom of on one of these pages:
https://support.google.com/googlenest/topic/9300123?hl=en&ref_topic=9300014
https://support.google.com/googlenest/topic/9299926?hl=en&ref_topic=9300014
ai
Hi there Snowbird20,
Thank you for your patience with us! We've created a case for your issue to send to our support team. Be on the lookout for an email from us in your inbox soon. For reference, your case number is 3-6534000032064.
Kindly,
Ai
