04-09-2022 11:41 AM
I just installed my Wired Nest Hello to a working Mechanical door bell system. I can't get the mechanical chime to work when the chime connector is installed. When I remove the chime connector from the mechanical chime the chime works well. It's like the chime connector is bad and not allowing the small voltage to pass through to enable charging of the Nest Hello internal battery. I don't know what to do from here. Please advise.
04-09-2022 12:15 PM
I'm just another Google Nest customer with Google Nest Hello Doorbells. The Chime Connector provides continuous power to the camera in the Nest Hello doorbell without triggering your indoor chime. It could be faulty. Check that it's wired correctly (as in the diagram in this post: https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Video-doorbell-wiring/m-p/117681) and that your transformer meets Google Nest's requirements (https://support.google.com/googlenest/answer/9247132?hl=en).
Also, some of us had to turn on "Chime duration" (intended for electronic chimes) and then turn it off again to get our indoor chime to work.
04-16-2022 07:16 PM
Thanks for reaching out. I appreciate the help @MplsCustomer. How is your Nest Doorbell set up? Did the steps shared help?
Steve
04-19-2022 10:49 PM
It's me again. I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
04-20-2022 11:10 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
04-22-2022 08:01 AM
Hey Folks.
