Nest Indoor Camera in unheated Garage
d-j-c
I am just wondering if it is ok to install a Nest Indoor camera indoors in an unheated garage. The only negative is that it will get cold out there in winter but it's dry.
DC
@d-j-c
We've had an older 1st gen Google Nest Indoor Camera on the west wall in our unheated detached garage for almost 2 years now, through 2 Minnesota winters, where it can get as cold as -20 degrees Fahrenheit, and it's always stayed online. Maybe we've just been lucky. Or maybe, because the garage is usually 10 to 20 degrees warmer than outside in the winter, and with the camera generating a little heat, it's enough to keep the operating temperature above zero degrees Fahrenheit.
7 REPLIES 7
David_K
It depends how cold. You can find the operating temperate ranges for Nest Cams here.
Technical specs for Nest cameras and doorbells - Google Nest Help
d-j-c
Thanks, I can't imagine it would be less than zero, I assume there is no danger if it does, it just may not work?
David_K
No danger no, but it could damage the camera and not work.
Princesss
Princess
Princesss
Hello folks,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest devices and we'd be glad to assist you further.
Princess
@d-j-c
EmersonB
@d-j-c, thanks for reaching out here in the Community. How's it going with your Nest Camera? Were you able to read the information they've shared above? In case you have an update, you know where to find us.
I appreciate the help, davidking and MplsCustomer.
