Nest Wired Doorbell - Does Not Ring Immediately - It Takes 4 - 5 presses
jlika
My Nest-wired doorbell is no longer ringing on the first button push.  It now takes 4 - 5 pushes before it will ring.  My electrician has looked at it twice now, and of course, it worked both times on the first touch for him.   The video function on the doorbell is working fine with no issues and works perfectly on my iPhone.  It's just the intermittent chiming that takes several attempts before the chiming begins.  No visitor is going to ring a doorbell multiple times.  it should work on the first button touch.  My electrician has no idea how to fix the issue.
Ashepherdson
Is the notification on your Google devices not working, or the chime, or both?  Have you tried rebooting the hello and your router (I doubt it's a connection issue since you said video works fine).  Is the button hard to press ? Ie could debris somehow have got underneath the button ?
