11-26-2022 07:00 PM
Hi just switched internet provider and can’t reconnect camera with the six digit code? Don’t have qr code
11-27-2022 06:25 AM
Google Nest does not make it easy to change Wi-Fi settings, so they recommend setting the network name (SSID) and password on your new router/modem to the same values used on your old router/modem. If you can't do that, then you need to remove the camera from your Google Home app or Google Nest app while you are still on the old Wi-Fi network, do a factory reset, and then reinstall it (https://support.google.com/googlenest/answer/9223711?hl=en).
11-30-2022 09:44 PM
Checking in — did you get a chance to try the suggested steps provided by MplsCustomer? If so, how did it go? Let me know if you need more help.
12-03-2022 10:33 PM
Hey G44,
12-04-2022 10:45 PM
Just checking in to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
12-05-2022 04:07 AM
It was replaced!!!
12-06-2022 02:08 PM
Gotcha, glad to hear! To make sure, do you have other questions or concerns?
12-09-2022 02:54 PM
@G44 we're bumping up this thread to make sure that everything is covered and to check if you still need any help. Let me know if you have any additional questions from here.
Thanks for lending a hand, MplsCustomer and JT.
12-10-2022 03:41 PM
Thanks for chiming in, Emerson.
