Nest camera and floodligh
Freeman2468
I just purchased a nest camera and floodlight not realizing my existing floodlights is mounted under my Eva can I still mount my flood lights under there or do they make a Universal mounting base
Hi there, sorry about the delay.
The Nest Cam with floodlight is only designed to be installed on vertical surfaces like a wall. It is not designed to be installed on horizontal surfaces because the downward facing angle would reduce the floodlight’s functionality by limiting the field of view of the PIR motion sensor (which triggers the floodlight when motion is detected). Hope this helps and we've also shared your feedback with our team.
