06-26-2024 11:42 AM
The cord I'm looking to buy on amazon says Google nest cam cable (battery) only -720p -snow- 5m. Will this cord work for the newer Cameras with 1080p and nest aware? I just bought a new indoor/outdoor camera.
06-29-2024 04:00 PM
Hello @5812jrz,
Thanks for reaching out to the Google Nest community! I appreciate you considering Google products as you explore replacing your Google Nest camera indoor/outdoor cable.
I understand that navigating cable replacement options can be overwhelming. Since you recently purchased a Nest indoor/outdoor camera, it seems you're interested in a solution that integrates seamlessly with your smart home.
The cable you're considering might work, but I recommend sticking with the original cable for optimal compatibility. In this case, I would like you to fill out this contact form to get further information or options.
Please let me know how it goes or if you have any other questions.
Jorge
