10-08-2022 10:02 AM
Have had the doorbell for a while and can no longer turn the camera off through the app. I tried deleting the app. Was working until recently. Still has WiFi connection as I can see live video and it records events. When I try to turn off camera from the app I get the white wheel of death (endless clocking). Please help! Thank you.
10-13-2022 08:46 AM
Same problem. Have factory reset, removed and reinstalled, nothing works very long. Worked fine until recently. Why no answers from "experts"?
10-13-2022 10:28 AM
10-13-2022 12:42 PM
Already done. As I stated I have performed a factory reset, removed it from the mount, removed and reinstalled the device, uninstalled and reinstalled the Home app, nothing has corrected the issue. My wife has the same issue when using her Pixel phone. No issues with the other Nest doorbell or cams in the house.
10-13-2022 03:48 PM
Sorry to hear you're still experiencing this. Have you attempted to try this from a non-android or pixel device? That may be a good step to try if you can. This could be another tablet, or phone with access to your Google home app.
10-13-2022 04:31 PM
Unfortunately/fortunately??, I am a loyal Android/Pixel user and don't own a non-Android device:-(. I don't believe I can access from a Windows computer, unless you know otherwise?
10-16-2022 07:57 PM
Hey OriginalPolo,
Thanks for following up. Live video is available only for 2nd gen Nest cameras and doorbells that you control with the Home app.
Here’s how to turn off your Nest Doorbell (battery):
Note: If your camera is already turned off, you’ll also find Turn on camera near the bottom of the live view screen.
Let me know how it goes.
I appreciate the help here, Brad.
10-19-2022 08:46 PM
It's me again. I want to make sure you're all good — how did the steps go?
10-21-2022 09:45 AM
@OriginalPolo we haven’t heard any updates from you. I’ll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
@Jt and @Brad I appreciate your help.
