Nest doorbell battery low temperature warning
GBD
Today I've started getting "Low device temperature" warnings from my nest doorbell battery. It's 27c outside so what's up with that????
@GBD
Perhaps you could try contacting Support; it sounds like you may have a malfunctioning doorbell:
GBD
Thanks.. Customer support sent me instruction on how to factory reset to fix this error 😞 I hate factory resetting things, something always seams to go wrong when doing that.
Wish me luck.
HanzC
Did that solve your issue? My Nest camera started doing the same and I'm hesitating to factory reset because of the inconvenience and because I think it might be just an incorrect notification, but not the actual temperature of the device
I'm sorry to say that it didn't fix the problem and I'm kind of leaning towards it being a hardware problem with the temperature sensor in the doorbell. Everything else works fine with it except that I keep getting that low temperature warning but, It's not as if I paid any attention to the warning even when it is cold outside because I have it powered with the optional power adapter.
