05-01-2022 12:52 AM - edited 05-01-2022 12:53 AM
I've just installed the Nest doorbell battery
When I ring the doorbell it only announces on one of the google minis (in my child's bedroom)
I want it to chime on my google nest which is located in my kitchen - is this possible?
TIA
05-01-2022 09:13 AM
Visitor announcements are supposed to be sent to every Nest Hub and Nest Mini (and certain other Nest devices) that are in the same "home" or "structure" in the Google Home app, and Google Nest does not give us an option to configure them separately.
05-01-2022 06:53 PM
Hi Chan2558, Mpls is correct. The only thing I can think of is the one in your kitchen set to have all the alerts turned OFF?
To check this go into the Google Home app and select the device in the kitchen. Then hit the gear in the upper right corner and select Notifications & Digital Wellbeing. Make sure the Do Not Disturb option is not turned on.
Hope this helps. Please return here and let us know if and when you find a solution.
05-01-2022 10:17 PM
I appreciate the help @MplsCustomer and @EmptyNester. I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
05-02-2022 11:09 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
05-02-2022 11:47 PM
Thank you everyone for your suggestions
The nest, doorbell and minis are all linked within the same home structure. And the DND is not turned on and the door bell is still only going to minis. When I ask the nest to show me my front door it links me to the camera but the bell just won't chime on the nest when rung. Very frustrating as the doorbell is useless if I can only hear it from the kids bedrooms.
Any other suggestions?
Ands is it normal that I can't add the nest doorbell to the Nest app?
05-03-2022 04:43 PM
Hi Chan2558, Well, I can tell you that I bought the Doorbell Battery to replace my Nest Hello and I ended up returning it about a week later because of so many limititations as compared to the Nest Hello. I just couldn't live with the fact that is started recording way to late (even when AC Powered) and people were often turned around and walking away before it would show me their face. And also that lack of the ability to see it from my computer's browser was a problem for me.
And the biggest issue of all was that the new doorbell (and all the new line of cameras) would not work with the Nest App. I have spent years using that app and I know exactly how to use it without thinking. And now here they go announcing it is reaching end of life and I have learn Google Home with is far inferior to the Nest App.
But more to your question, I ended up going back to the Nest Hello. The problem I repeatedly have is that I get an alert on my (2) google Hubs that someone has pushed the doorbell button but the 90% of the time the screen is just blank with a gray screen. I reboot the hub and it fixes it for about an hour then the problem comes scream back. I have given up that it will every work properly
Super frustrating!
05-10-2022 06:21 PM
It's me again. Just checking in to see if the troubleshooting steps shared helped. If you have other questions and concerns, feel free to let me know.
Steve
05-10-2022 07:04 PM
Thanks Steve
I actually got it working. I turned off the nest hub and reset the doorbell and it now rings to the hub
Thanks for everyone's help
05-10-2022 07:27 PM
I'm glad to hear that everything is working and thanks for sharing the steps that helped you to resolve your issue.
In the meantime, do you still have other questions and concerns?
Steve
05-16-2022 10:45 AM
Hey Folks.
