11-17-2021 05:01 PM
Having trouble with the wifi dropping every second or third day since installation of the doorbell.
Would the doorbell be causing this issue.
New modem installed same issue.
12-17-2021 11:22 AM
01-11-2022 02:36 PM
Issue is still happening
01-12-2022 08:55 AM
It sounds like this is an issue related to your wifi/internet. The camera will drop in and out of wifi if there is a low signal, or issues with the wifi. It can also go in and out if it is too far away from your wifi router. Your router should be as close to the doorbell as you can move it comfortably. Restarting and factory resetting your Google Nest camera or doorbell will have different results:
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
Factory reset: Erases all your settings and options, and restores its factory default settings. It will not automatically reconnect to Wi-Fi and you'll need to set it up again.
You can find this information, plus additional information on this process here. Please let me know if you have further questions.
01-13-2022 01:41 PM
Hey Folks.
01-11-2022 02:26 PM
Just checking in to make sure that you saw our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Have a great day.
Garrett DS
