01-13-2022 08:25 AM
I've had the unit installed for over a year and have been fairly happy with it. But after going through it's first Southern California summer I noticed a bunch of clear flecks on the surface. At first I thought they were from a protective film I'd forgotten to remove during installation, but it wasn't. After the recent heavy rains I am seeing more and more of this thick laminate coating flaking off. I can see two tiny spots under the glass covering the lens area and can see a slight diffused quality to video at night that wasn't present before. I'm concerned that the weatherproof qualities are gone and it's failure is an inevitability. Not very desirable in a device that is meant to spend it's entire existence outside, around the elements. Is there a product anyone can recommend to repair this?
01-13-2022 08:38 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
