Nest doorbell wired
Justinave
Hello, I set up my nest wired doorbell and it was working fine. All of a sudden it is ofine amd no lights or anything appear on the doorbell. Please advise, thanks!
BinaryJay
Product Expert Alumni
Either it's defective or it's simply not getting power (more likely).  Remove the doorbell and use a multimeter to check the wires to ensure they get the amount of voltage required to run the doorbell.  It could be something as simple as the wires weren't connected securely and have come loose, or a breaker needs to be reset.  If you can confirm the power at the wires is correct then you'll probably want to exchange the doorbell.
Thank you for your response, the jest is now working without me doing anything. It was offline for a few days now seems to be back. Could it have been caused by extrmem cold temperatures?
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
