Nest doorbell with Echo Show 15 Trouble
Tmarsillo
Hello all I’m hoping someone out there can help me.
I am having trouble setting up my nest wired doorbell to the echo show 15- to alert me when someone is at the door. I get this error saying live view is not supported on this device and cannot enter the setting to adjust motion announcements.
Any idea?
janthadeus
Hi Tmarsillo,
Thanks for reaching out! Setting up your Nest Hello Doorbell(wired) with your Amazon Echo show is still a product limitation and beyond our expertise. You can try these following steps:
Add a new Nest thermostat, camera or doorbell:
  1. Add your Nest device to the Google Home app.
  2. At the top right of the app home screen, tap your account profile >  Home app settings.
  3. Tap Partner Connections > Amazon Alexa.
  4. Turn on permissions for your new device.
  5. Say “Alexa, discover my devices.”
Remove a Nest device:
  1. Do either of these steps.
    • Turn off Alexa Partner Connections permissions for that device.
    • Remove your device from the Home or Nest app.
  2. Wait a few minutes, then refresh the Alexa app.
For your setup guide and skills integration you can go to Control Nest products with Amazon Alexa. You might want to reach out to Amazon Alexa for further assistance.
Let me know how it goes.
janthadeus
Hi Tmarsillo,
Checking in to see if you still need help with this. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
janthadeus
Checking in to make sure that you saw my response. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
