02-22-2023 06:44 AM
Two of my cameras stopped working - diff elec circuits.
cannot reconnect- tried we code, nothing, used 6 digit code- goes through setup process, then ask for last digits of serial number, then app locks- no place to put numbers. Get a nc023 code also.
had tech come out - he had no luck either. Surely, two cameras did not die at same time.
also a side comment; many comments about not having at code or 6 digit code. Put data design on nests/googles part as that info should be in a database at time of manufacturer. I can get to me in for: $185 tech visit.
02-27-2023 10:15 AM
03-02-2023 10:37 AM
Let me know if you need anything from me, but I am just seeing how the conversation is going. We'll leave this thread open for a little longer for follow-up questions and concerns.
03-02-2023 10:48 AM
Worked with help desk, did factory reset, got one camera going after 90 minutes. Checked two days later to reinstall and it was out again. Trying to follow earlier steps again.
03-03-2023 08:32 AM
Please let me know how it goes and we'll leave this thread open for a bit longer.
03-04-2023 07:10 PM
It’s us again. Still need our help?
Thanks for your help, Brad.
03-05-2023 07:13 PM
