11-18-2021 09:46 AM
I just installed a Nest doorbell and tested the function to speak to visitors. The volume is so low that my voice can barely be heard. I can't find a volume setting for the doorbell anywhere on the app. I am using a Galaxy S9+ phone for the Nest app. I found another thread on this subject, which ended up being locked, and there was no resolution to this issue. It seems that many people are experiencing this problem with their doorbells. Do you have any sort of advice or resolution to this problem?
12-17-2021 11:46 AM
12-28-2021 11:40 AM
Brad,
You give the same response to every thread. How about a solution from Google? just bought the doorbell and have the same issue. I have an Samsung S20 phone.
01-18-2022 11:16 AM
I have been the only Moderator over these forums for months now, I am sorry I am stretched a bit thin. My responses are meant to ask if you still need assistance, and to make sure I can reach those in the community. Hard for 1 person to do, but I am doing my best. Thank you for your feedback.
