10-25-2025 05:48 AM
I have been going crazy trying to find a solution for this problem. Since migrating from nest it has been nothing but problems. Every time I unplug the cameras they work for about half a day and then mysteriously go offline. I have one nest battery outdoor camera that works perfectly fine. Unfortunately, two wired outdoor nest cameras are useless. I’ve tried deleting the cameras, adding them again a few times. I just don’t understand how they could work perfectly fine on the Nest app, but then when I finally migrated to the home app where I had the battery nest camera, hoping everything would be under one app and working as it should, I can’t be the only one can I?
10-25-2025 12:44 PM
Hmmmmm, I Have transfer 3 of my older cams and not had this issue. You may want to open a support ticket and speak with a real nest support person. Here is the link to get you going....
10-27-2025 10:02 AM
10-28-2025 02:40 PM - last edited a month ago
Hi Folks,
Thank you for posting in the community. I see you're having trouble with two Nest Cameras Outdoor Wired that keep showing offline after the migration to the Google Home app. I understand how frustrating this must be, and I appreciate all the troubleshooting efforts you've already taken. I'm here to help.
For better assistance, please answer the following questions:
Please keep me posted on your findings.
Byron
3 weeks ago
Having the same problem with two cameras. Worked with the live help nothing worked, so they kicked me up to the senior live help. That has been useless. nothing works. They told me if they think of anything they will email me. Otherwise, I'm out of luck, no way they or I can put them back on the Nest App. They did email me a list of things to do that I have no idea what they're talking about. All above my knowledge level. They then said i should work with my internet provider as it's not their problem. Wait a minute, everything else I own works fine and these two cameras worked fine until they got me to transfer them to Google Home, how it is not their issue?
3 weeks ago
Anyone that figures this out, please let us know.
3 weeks ago
Hi tmer,
Thank you for posting in the community. I'm sorry you're experiencing trouble with two Nest cameras that show offline, and that you contacted customer service but still can't connect after they provided troubleshooting steps to resolved this situation. I understand how frustrating this can be. Help's here.
For better assistance, please answer the previous questions provided.
Additionally, what is the case ID for your previous interaction with customer service?
Byron
3 weeks ago
1) Nest Cam Indoor both
2) Slow flashing blue
3) iPhone 17
4) 3 feet for one and 30 feet for the other. Same location that they have been working 100% in for 4 years
5) yes
6) no
7) no
😎I have not seen an option for that when I try to connect
9) Nokia Model XS-010X-Q
Nothing has changed except the transfer to Google Home. Worked for last 4 years. Google Home must have downloaded something to the cameras that stops them from connecting or, on one occasion, from connecting for more than 6 hours.
5)
3 weeks ago
Case ID: 2-7037000039290
3 weeks ago
I have the exact same issue. My two 2nd Gen outdoor wired Nest cameras consistently drop from the Home App. They worked flawlessly with the Nest App. I have 3 other Nest indoor cameras that work just fine on the google home app. I have uninstalled and reinstalled said cameras only for them to lose connectivity a day later.
3 weeks ago
Yes, this is frustrating. I have the same issue. Bought a new Camera which will only connected to the google home app so i migrated my existing two camera from nest to google. Now the old cameras do not work except for a short time after unplugging. Come on Google, lets do better. Please help us.
3 weeks ago
To follow up, I performed a hard reset of all of my cameras. I also checked my router setting and the ip addresses for all the cameras. Since doing so, I haven’t had any connectivity drops on the Google home app. If it does temporarily drop a signal, it comes back shortly. Baby steps.
2 weeks ago
I am having same exact issue.
