09-01-2021 02:52 PM
Original poster: Outdoorcam
2021 outdoor camera battery - Extensive testing indicates a 10 minute cool down for person notifications. I have set to 30second recording.
09-01-2021 02:53 PM
09-21-2021 11:11 PM
Any future plan for this issue? 10 mins is way long and not reasonable. At least it should be less than 5 mins.
This is the one of the reason that I am not buying more nest cameras. I really wish I can get some updates on this matter.
09-22-2021 07:11 AM
Yes 10 minutes is WAY to long. The software needs to be able to let you use set this. Maybe 0-10 minutes would be good. But for me even 5 minutes would be to long.
12-27-2021 05:59 PM
Has there been any update on this issue? Conducted several tests of the Outdoor cam, wired for power, with all settings maximized. All notifications enabled. Once triggered, subsequent notification will not trigger for 30 mins (first test) and 10+ mins on another test.
