Next Doorbell Wired Compatability
BigDaddyBigTent
I am trying to confirm if the Nest Doorbell wired is compatible with my current chime. The current chime is an Emerson Model C8204 VOLTS AC 10-16. Can anyone help me out with info? Thanks!
JuanCH
Hi BigDaddyBigTent,
Thanks for reaching out to the community! I understand you'd like to know the compatibility of your current chime with the Nest Doorbell wired, I'm happy to help you!
Google Nest doorbells are compatible with most of the chimes, But, some can't deliver enough power. You can check your chime compatibility using the Nest Doorbell compatibility tool.
Keep me posted.
Juan
