No door bell notifications / livestream from Google Nest doorbell wired on a Google Nest Hub
ON42
I have just installed a new Google Nest Doorbell wired. I try to get a live stream on my Google Nest Hub ( 1st Gen ) but it only works once after factory setting of the Google Nest Hub. The same issue with my Google Mini ( 1st Gen ).
So the complete factory reset of the Nest Hub and Mini only helped for one doorbell event, after that it stopped working again. Does anybody has an idea to fix this properly ?
@ON42
How would you livestream your doorbell's camera on a Nest Mini? Are you talking about "Visitor announcements"? "Visitor announcements" should go to all Google Nest Hubs, Nest Minis, and Nest speakers in the same Google Nest "home/structure". They should work as described in the link below, but I've seen a few posts in this forum from customers having problems with "Visitor announcements" from the 2nd Gen Google Nest Doorbell.
https://support.google.com/googlenest/answer/7672451?hl=en
Indeed the issue was related to Visitor Announcements. I have a applied a factory reset on my google nest hub according the way it should be , and the issue is now solved. Thanks for your reaction.
aatienza
ON42, thanks for the update. Let us know if you have other questions as I'll be locking the thread after 24 hours
Archie
aatienza
Archie
aatienza
Archie
