No issues for 2 years door bell rang and went offline
Beltmatt_usa
Also this is the nest wired doorbell but it wasn’t an option.
I’ve had this door bell for 2 years with infrequent issues but yesterday after it was rang it went offline and will not return. I reset the power but nothing.
it is -25F with wind chill going below -40F
kiltguy2112
You are well below it's specified operating temp of -4F. It has a storage temp down to -40F. So it might start working again if it gets warmer.
James
Hello @Beltmatt_usa,
Just wanted to check in here to see if you had any follow up questions or needed any additional assistance from us? Let us know when you can.
James
