09-02-2021 05:03 PM
I have a Outdoor Nest Cam IQ. The installation was 14 months ago by google pros. The power cable has failed, and the only way I could fix it was to purchase a new camera. Cannot find replacement cable anywhere. Now I have an extra $360 camera I would like to use.
09-09-2021 03:28 PM
Hi there, jd.
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. Thank you for bringing this information to my attention.
Look forward to your response. Please let me know if you need anything else.
Best Regard,
Brad C.
09-12-2021 07:18 AM
I have a nest cam IQ camera that does not work due to faulty power cable. I can find not replacement cable anywhere. I was forced to buy an entire new camera to replace the cable. I was told by the ONTech installer that when the cable went bad, one had to replace the entire camera (and thereby throw a $359 camera in the trash. I did not believe that could be true. But apparently it is. How do I obtain an new cable so I can install my new camera?
09-11-2021 08:25 PM
Have a great day!
Hilary
09-12-2021 07:20 AM
I would like to find a new cable so that I can install my new camera in another location at my house. So no, my original query has not been answered.
09-12-2021 07:25 AM
Thank you for writing.
I purchased a nest door bell and 2 nest cam IQ cameras for outdoor security. These were purchased and installed from Google recommended installers, On Tech on May 29, 2020. I noted one camera was not working a number of months ago, but did not call OnTech until this month. When the repairman arrived he said the camera was bad. I could either install a whole new camera or one on the newer model wireless versions. I was of the correct mindset that the camera was fine, and there was a problem in the power wire. To get a new power wire, I had to buy a whole new camera. I did so, thinking I would install the new camera once I obtained new wire. I found it shamefully wasteful to throw away a perfectly good expensive camera for lack of a wire. However, there is no replacement wire anywhere to be found. Thus, I have a brand new, in the box camera that cannot be used and spent nearly $400 getting to this point. I need a new plug and wire to install the new camera.
Any advice???
Thank you,
JD
09-12-2021 07:39 AM
Hi Jd, I found this on Amazon. Is this what you are looking for?
