12-30-2023 02:13 AM
Like many others one of my nest Outdoor cameras now has a pink hue on the day time video feed.
I have read many similar posts on here and followed the advice to limited or no success.
Turned off and off, left off for a while reset the unit, turned night vision auto on and off etc etc. Yet to no avail.
I can't see any actual resolution to the issue and all of the previous threads are closed for replies? Dose anyone have an actual solution?
My camera is located under a porch roof so not directly exposed to the weather faces North so no direct sunlight and we live on the 56th parallel north (latitude 56 degrees north) so overheating seams a little far fetched also the camera was installed in the same location since 2016/7.
12-30-2023 07:45 PM
Honestly I think your best bet is to just buy a used one on Ebay (they are not very expensive) and retire this cameras a broken. I have purchased a few off ebay in the past few years and they are still going strong. Including a Nest Hello doorbell. Google will not help in any way once it is past the 1 year warrenty.
