02-22-2025 07:05 PM
I bought a house with a Nest thermostat and outdoor, hard wired camera. I am trying to add the camera, but there is no power light and the wire goes into the concrete block. The green power indicator is not on, and I've tried out all the other electrical things out there and it all works fine. I have a Ring camera hardwired where the porch light used to be. It's about 3 feet away from the Nest cam. The Ring product works fine and has power. No breakers are tripped. Short of calling an electrician, is there anything else I can try? Any chance it's been discontinued and stopped getting power? I can't seem to Google whether the support for this model has been discontinued or not. BKUKJ2 Thanks!
02-26-2025 08:16 AM - edited 02-26-2025 08:58 AM
Hi NinaL,
Thanks for reaching out to our community.
I’m sorry to hear that you found that the outdoor, hardwired camera installed in the house you bought has no power light. Thank you for letting us know important details such as the camera not showing the green power indicator and you’ve tried out other electrical devices out of your house, and it all works fine. No worries, help is here.
Before I start further troubleshooting, let me ask you a few questions:
In the meantime, I recommend you try the following troubleshooting steps:
Thanks for your kind attention; I will be looking forward to your response.
Virna
