12-12-2022 10:46 AM
Hi
For several days I have had a problem viewing my cameras and door bell live stream on my mobile via the Nest App. There is no problem with access via the browser and nest website. All I get on the Nest app summary page via my mobile is a series of black screens under door bell, camera 1, camera 2 etc, with the revolving blue circle like a buffering image on video. This does not happen when i access the same via the website. i have tried rebooting, reinstalling and most other easy fixes without success. I also know the system is set up properly as it also works properly on my ipad, but not my mobile! has anybody seen this problem before?
12-12-2022 10:58 AM
I'm having a similar issue where I cannot see the nest hello camera over a mobile network ( and assuming not notifications) but works over WiFi at home and at work. Hope there is a fix soon otherwise it gets sent back and I'll get a Ring doorbell
12-12-2022 11:47 AM
If you're having trouble on your mobile while using Wi-Fi, you could try deleting and reinstalling your Google Nest app. If the problem is only when using the app while on cellular data, there have been other reports about that, with no answer from Google Nest yet.
12-13-2022 03:37 AM
Hi
thanks for this. I get the problem on my mobile on wifi or cellular so suppose will have to wait for Google response. I have tried reinstalling the app several times with no success.
12-19-2022 10:26 AM
12-26-2022 04:07 PM
MetaDragon, have you tried updating your Nest app on Google Play Store?
Frenske, awesome, glad to hear!
12-29-2022 04:58 PM
It's us again. Were you able to try updating the Nest app on Google Play Store?
Archie
01-03-2023 02:28 PM
Hello there,
Archie
01-04-2023 07:07 AM
Yes, I did and I did the update and it fixed my problem. Thank you.
01-11-2023 06:32 AM
Hi everybody,
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
01-13-2023 07:23 AM
12-14-2022 04:21 AM
I'm having the same issue. 5 outdoor cameras, spinning blue circle on all of them on nest app dashboard. When I click on each camera, the live video pops up fine. I've had two Android updates recently, not sure if that is related. Cameras are working, good power and wifi. Reached out to nest, still waiting on response.
12-15-2022 09:46 AM
Hi All, I have this issue since the last update of the samsung firmware. After the update I got this behavior. I think this is a problem created by Samsung.
12-17-2022 11:55 AM
Having same problem with Nest app on my Samsung S20. Any word on a fix?
12-17-2022 03:17 PM
I'm having the same issue on a s22, a friend has the same issue on a s20.
01-05-2023 12:43 PM
Hello everyone,
@msgnome2 thanks for getting back to us and we're glad that it's working now. Let us know if you have more questions in mind.
@MetaDragon and @gsxrkllr were you able to update your Nest app through the Google Play Store app? If so, how did it go?
I appreciate your help, JT and Archie.
12-20-2022 12:54 PM
Also having the same issue. Started a week ago. Only happens on cellular data. Works fine on home wifi. Nothing fixes it. Tried logout/login, clearing app cache, clearing app data, restarting phone. Only summary page it's malfunctioning. Tapping on the cameras thumbnails opens the camera specific feed with no problem.
12-21-2022 03:09 AM
In Google Play Store there is an update available. It's working !
