Replacement parts
Prs7
I just realized that the lense cover on my wired outdoor camera is missing. Is there a replacement that I can get? I also was looking for 2 mounted for the usb plug box because we moved and I must have left them.
Thanks in advance!
Rubes
Unfortunately replacement parts like this are not available. You can try contacting support for a replacement as that’s about your only option.
EmptyNester
Silver Product Expert
hi Prs7,  this is a user forum that Google doesn't really look at.  For this problem try getting help from Google themselves by opening a support ticket.  You will need the serial number of your camera.  Here is the link:
Thank you for your patience! Unfortunately, we do not process Warranty/Replacement Requests in these Community Forums. This includes replacement parts. Like @Rubes and @EmptyNester stated, there are some other options you can try with Support, but you will need to go to them. If you are seeking a replacement, please contact Support
aatienza
Hey Prs7,
Archie
aatienza
Hey Prs7,
Archie
