Reset doesn't work
HG2
I moved to a new house and inherited wired nest outdoor camera
I tried the reset button but didn't work several times.
I also tried unplugging it but again didn't help
Please advise how to reset my camera if the reset button doesn't work?
Thanks
8 REPLIES 8
David_K
Are you following the steps in the help article below? The key thing is when the light ring starts spinning blue, release the button. Your camera’s lights will turn off while it’s resetting.
https://support.google.com/googlenest/answer/9252162
See the "Nest Cam IQ Indoor or Outdoor" section under the "Factory reset" part at the bottom.
HG2
Thanks for your help
I tried all the steps mentioned
The problem that pressing the reset button doesn't work,it doesn't change in color,not sure if button defect or not.
Any other ways to reset?
Thanks
David_K
Is your camera plugged in and powered on? Are you using an unfolded paperclip or thumbtack to reach the reset button?
HG2
Yes.
Tried pressing for short period and for longer but nothing worked for both cameras
David_K
Let me ask a specialist to suggest further troubleshooting options or next steps.
aatienza
Hey HG2,
I’m sorry you’re having trouble with this. No worries, we'll check this out. Could you fill out this form and let us know once you're done?
Archie
aatienza
Hey HG2,
Archie
aatienza
Hey HG2,
Archie
