Setup doorbell battery offline
Nicolercreech
I have installed this at least 40 times.  Each time i get to the feed and it is offline.  I can not get it to connect to the live feed so i can mount the doorbell outside.
gmelanymelissa
Hi there!
Thanks for posting here in the community. I'm sorry to hear your Nest Doorbell Battery is offline. I'm happy to help!
To better understand the situation, I'd like to ask a few questions:
  • Are you getting any error messages?
  • How far is the doorbell from the router?
  • Do you have other Nest devices in the house?
  • Are there other devices connected to the same Wi-Fi where the doorbell is connected?
  • What is the status LED light?
  • Has the camera ever successfully connected to this network?
In the meantime, let's check a few things:
  1. Make sure your doorbell is fully charged: If the battery is low, the doorbell may not be able to connect to the network.
  2. Check your Wi-Fi connection: Make sure your Wi-Fi signal is strong and that your router is working properly.
  3. Restart your Nest Doorbell: This keeps all your settings, and it should reconnect to the same Wi-Fi network. Refer to this article to Restart your Nest Doorbell Battery.
Keep me posted.
Melany
