Solar charger for Nest doorbell
Ngupta
Hi - Looking to see if somecan share specs of a solar panel that they maybe using with these doorbell battery. We have a couple but do not have charging points near the doors. Hence thinking of installing solar chargers but confused what specs I should be looking for when buying the same.
Help appreciated.
tajennifer
Hi Ngupta,
Thanks for your post. I understand you're interested in getting a solar panel for your Nest Doorbell (Battery). I'd be happy to share some information with you.
We currently recommend the Wasserstein Solar Panel for Nest Doorbell (battery), this panel stores solar energy and charges your Nest Doorbell (battery) as needed. This is available on the Google Store where you can take a look for more details and specifications.
I hope this helps!
Jenny
