Solid Red Light
icenet333
Hi All,
In searching the past answers to this question, I have yet to find a solution to a solid red light on a Nest Indoor Camera. I tried unplugging, and it didn't work. It seems to be recording fine thought.
Thank you
@icenet333
I don't think there is a solution. It just means the status light isn't working. Google Nest Help says "If there's a solid red status light, it means the LED isn’t working properly. Contact Nest Support for help."
https://support.google.com/googlenest/answer/9268073
@icenet333
icenet333
Thanks!
Lance_L
Hi icenet333,
Thanks for posting — as we've got our resolution here, I'm going to mark this thread as resolved. I'll be locking this thread if we don't hear back from you in 24 hours. Should that happen, feel free to create a new one if you have other concerns in the future.
Appreciate the help, MplsCustomer.
Lance
