Standard volume on mini's and Hubs when doorbell is ringing
Francois
Is it possible to make sure that the ringing of the doorbell is heard over all other google devices (like mini's, smartphones, hub's) even if their own volume settings are low?
regards,
Francois
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. The volume will only be set to whatever it is set as for each display/speaker or setting. I know that you cannot change the sound for when the doorbell is rung, but it will go over whatever settings your devices are set too.
janthadeus
Hey Francois,
Thanks for the help, Brad.
janthadeus
