05-02-2023 07:34 AM
Is there a way to use the battery doorbell without the mounting bracket? I lost it and would like to use it without the mount bracket
05-02-2023 08:25 AM
Wasserstein sells a no-drill mount (using adhesive tape) that can be found on Amazon. I have no idea about its quality, and we have Nest Hellos, not the battery doorbell. I think you might have to change your mount type to a non-Google mount under Settings | Device information in the Google Home app.
05-02-2023 08:36 AM
@MplsCustomer Thanks for your reply. I did look at the Wasserstein, but it looks like you still need the doorbell mount bracket to use it. The doorbell is off and seems like the mount bracket turns it on. The mount type on settings only applies to other cameras, the doorbell does not show that option. Appreciate your help
05-06-2023 06:35 PM
Checking in — I hope you've got the answer you're looking for. Let me know if you have more questions in mind.
I appreciate your help here, MplsCustomer.
07-07-2023 07:33 AM
I've bought a used doorbell on ebay. It only had the doorbell and the original package.
Do not see an option to change mount type in Settings | Device information, only the device information itself.
07-07-2023 07:51 AM
Since the "Camera mount" option is apparently available only on the battery camera not on the battery doorbell, you may not be able to use your battery doorbell without the mounting bracket.
07-07-2023 08:24 AM
Thank you for the info.
That's an unfortune. Do you by chance know how to order a new one?
07-07-2023 08:28 AM
Unfortunately, Google Nest does not sell any spare parts, unlike some of its competitors. Whoever sold you the doorbell sold you an incomplete product.
You could try contacting Support, start with this link and click "Next step" on the "Resources" page without selecting any Help topics in order to get to the contact options (chat or phone):
If the doorbell is less than a year old, perhaps they'll consider covering it under the warranty.
07-07-2023 09:18 AM
Thank you for the suggestion @MplsCustomer.
I've contacted the support and they've proposed to replace the item.
07-14-2023 09:30 PM - edited 07-14-2023 09:33 PM
Hello everybody,
@chitorivera223, I'm bumping up this thread to ensure that everything is covered here. How's it going with your Nest Doorbell?
@CanuckNorth391, please post here the photo of your issue so that we could take a better look.
@bnels97, we appreciate you sharing here what you've done about your concern.
@veton, can we have an update about your replacement? Were you able to receive it?
Thanks for answering, MplsCustomer and JT.
07-17-2023 10:32 PM
We wanted to follow up and see if you are still in need of any help. Please let us know if you are still having any concerns or questions from here, as we would be happy to take a closer look and assist you further.
07-18-2023 02:38 PM
Hi Emerson,
Thank you for checking on the issue. The doorbell is not functional without the mount.
I'm still waiting for the instructions from Nest Support to get the replacement.
07-18-2023 10:59 PM
Hi veton,
Thanks for getting back to us. Were you able to receive an email regarding your replacement? What did they advised you? Looking forward to your response.
07-19-2023 04:48 AM
Its a bit of a back-and-forth, and usually takes 1-2 days to get a reply. There is a shortage with specific Ash color I have, so we also trying to overcome this point.
Would be much easier if I just could use the doorbell without the mount...
07-20-2023 11:26 PM
Hey veton,
We truly appreciate your update. It's good to know that you're in touch with them. We would recommend you to continue your conversation there to avoid confusion here. Let us know if you have more questions in mind or else we'll be locking this thread after 24 hours.
05-08-2023 11:08 AM
Replying just to follow the thread - I've had multiple issues where my doorbell does not properly mount into the mounting bracket, and now that my device is out of warranty, Google has been very unhelpful. I'd be interested in hearing about your solution to not using the manufacturer bracket!
06-11-2023 12:49 PM
Same issue here. The spring-loaded mechanism on the doorbell housing has failed and now won’t connect to the bracket; making the doorbell camera non functional. Any help or solution would be appreciated.
06-27-2023 05:56 AM
@CanuckNorth391 , from another thread, I found that using WD-40 Specialist Electrical Contact Cleaner in the release opening at the top, allowed the button to pop back out. Dirt and debris get in the release opening and jam the button in the unlock position when the device is used. I now keep a piece of painters tape on top of the opening and it's helped!
I'd spray the contact cleaner, and try using the release tool, back and forth until the button pops up again.
Hope this helps!
