Wasserstein not charging Nest Doorbell
S_Walker
I have the Wasserstein Solar Panel for Nest Doorbell (battery) I cannot get the doorbell to charge. I have plenty of direct sunlight but can't get a charge from it.
1000001180.pngI've disconnected the cables. While in direct sunlight and not connected to the doorbell, let the solar panel absorb 3 hours of sunlight. While I'm the sub, I charged the doorbell to 100%. Reconnected the cables of the Wasserstein back to the doorbell and no indication of a charge or that the doorbell is being charged.
chaconmorales
Hi S_Walker,
Thanks for reaching out to the Community. I am sorry to hear that your Nest Doorbell is not charging with the Solar Panel. But no need to worry, I’d be happy to help you with that. Let’s check it out.
Potential Causes and Solutions:
Solar Panel Placement:
  • Optimal Sunlight: Ensure the solar panel receives direct sunlight for most of the day. Adjust its position if needed.
  • Clean the Panel: Dirt or debris can reduce solar panel efficiency. Clean the panel regularly with a soft cloth.
Wiring and Connections:
  • Secure Connections: Verify that the solar panel is securely connected to the Nest doorbell and that all connections are tight.
  • Cable Length: Ensure the cable connecting the solar panel to the doorbell is not excessively long, as this can affect power transfer.
  • Voltage: Please check that the solar panel produces enough power to charge the Nest Doorbell.
Nest Doorbell Battery Health:
  • Battery Condition: A severely degraded Nest doorbell battery might struggle to hold a charge, even with solar power. Consider replacing the battery if it's old or shows signs of wear.
  • Power Consumption: High usage (frequent recordings, live view) can drain the battery faster, making it difficult for the solar panel to keep up. Adjust camera settings if needed.
Solar Panel:
  • If the panel consistently underperforms or does not charge any other device it might need to be reviewed by the manufacturer. Contact Wasserstein Support: If the issue persists, reach out to Wasserstein for troubleshooting guidance or potential replacements.
You can also try these steps to Troubleshoot low-battery issues for Nest cameras and doorbells or to check about Weather battery charging behavior in Nest cameras and doorbells.
Let me know if you need further assistance.
Mario
