12-10-2023 10:39 AM
Good morning,
I have a Nest IQ indoor camera that I've been using for a couple of years in the same spot and all of a sudden it stopped working. I brought the camera near the wireless router and did a factory reset by pushing the reset button with a pin, however after the initial chime and the yellow spinning light, it went dark and I never saw the blue blinking light. I've tried holding the pin in for some time and have had no luck.
I know the blue light is working since I see it went i unplug and plug it back in.
12-13-2023 07:15 PM
Hello akirkorian,
I understand that you're having trouble with your Nest Camera IQ. I'm here to help you get back online. Just to check: Have you tried using a different USB-type C cable to turn on the Nest Camera? Did you try connecting it to a computer or a different power outlet just to see if it would have power?
Edmond
12-15-2023 05:31 PM
I was able to get it to finally get to factory reset point, however whenever I try and readd it to my Nest account, it finds the camera but isn't able to set up the wireless. I've got the camera about 4 feet away from the wireless router and my mobile is about 3 feet away from both the camera and router. I have another camera that I tried and it worked right away without issues.....
12-16-2023 09:31 AM
Note that it specifically says the camera cannot connect to the wi-fi (error code NC006(3.10). I tried this multiple times and get the same result.
12-19-2023 05:03 PM
Thanks for providing all the information. I’m sorry to hear if you’ve been having issues reconnecting it back to the Nest app. Let me help you get back online. Just to check, have you tried using a different phone? Did you try creating a new home structure and connecting the Nest camera to see if you get the same error message? Or instead of connecting to your WiFi, have you tried using a mobile hotspot instead?
Edmond
12-20-2023 03:26 AM
Good morning,
Yes. I've tried with 2 different phones and my iPad with the same result. I've tried setting it up in the new home structure with the same result. I have another wifi router which I set up to try it with and again the same results.
I ended up a neighbor house and tried it there as well with his wifi and still no luck.
Cheers.
Alen
12-20-2023 04:09 PM
Hello there,
Thanks for trying — have you trying connecting to a mobile hotspot and see if you got the same error message on the Nest app?
Edmond
12-23-2023 03:36 PM
Good evening,
Yes. I got a mobile hotspot set up, and tried the whole process. I still get the same error where it is not able to connect the camera to the wireless.
Cheers.
Alen
12-26-2023 03:55 PM
Thanks for trying — we'd be happy to take a look into this for you. Please fill out this form with all the needed information. Let me know once you’re done.
Edmond
12-28-2023 06:02 PM
I wanted to follow up and see if you were able to fill out the form?. Let me know if you have additional questions.
Edmond
12-29-2023 03:41 PM
Sorry bust with the holidays. Yes, I filled out the form and submitted it this evening.
12-31-2023 04:59 PM
Hello there,
Thanks for filling out the form! Our support team will send you an email soon to help you out. If you have any more questions or concerns, please let us know..
Edmond
