Wired door bell
Echofox
Have got a new router how do I connect to door bell?
2 REPLIES 2
@Echofox
Google Nest does not make it easy to update Wi-Fi settings for its cameras and doorbells, so their first recommendation is to set the network name (SSID) and password on your new router/modem to the same values used on your old router/ modem.
If you can't do that, then the general procedure is to remove the camera from the Google Home app while you are still on your old Wi-Fi network (which should trigger an automatic factory reset), do a manual factory reset if it wasn't done automatically, and then reinstall it in the Google Home app while on your new Wi-Fi network:
https://support.google.com/googlenest/answer/9223711
zoeuvre
@Echofox, thanks for reaching out to us, and I'm sorry for the late response. I hope you've already gotten the answer you are looking for. Please let us know if you still have questions or concerns, as we'll be willing to assist you more.
I appreciate your help, @MplsCustomer
