05-28-2023 06:24 PM
My nest doorbell is wired and is constantly losing power and turning off to charge and missing a lot of events. Is this something that happens with the wired doorbells? I noticed another post that indicated an infinity sign signifies that it’s wired in but I don’t see that anywhere on my app. I just see a battery when the battery is low. Do you think it’s not wired appropriately? It is a busy street but I assumed it would never lose battery and turn off to charge if it was wired.
05-29-2023 12:56 PM
I have a second generation doorbell from Google (wired) since approximatively last september and it never loses power. I don't see any infinity sign anywhere either.
Perhaps your doorbell is not wired properly or, the transformer providing the electric current is not adequate. Have you verified that your transformer is adequate as per the requirements?
05-29-2023 01:02 PM
Or, are you positive that your problem is with the power source? If your camera is losing connection to your wifi, that could explain the loss of video recording. This is a very frequent problem reported in these pages and would be related to a deficient wifi signal.
05-29-2023 06:23 PM
I don’t think it’s a wifi problem as none of my other cameras have this issue. Must either be transformer or it’s not wired appropriately? I feel like I’m missing a lot of events because it’s out of power and charging half the time.
05-30-2023 03:42 AM
Can you check if the connections of your doorbell with the wire are tightly fitted? The wire connections could be loose. After you check this, if you still have problems, your transformer could be not adequate.
Out of the total of my five cameras, one did continously disconnect as it was some ways away from my router. I added a wifi extender and the problem was resolved. This to say, that if your router if some ways away from your router, this could cause the disconnects.
05-30-2023 03:44 AM
or rather, your router too far away from your doorbell...
06-02-2023 10:34 AM
@LGD88, thanks for reaching out here in the Community. How's it going with your Nest Doorbell? Were you able to follow the steps that gilleslibre has shared? In case you have an update you know where to find us.
I appreciate the help, gilleslibre.
06-06-2023 08:53 AM
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Doorbell? We would appreciate it if you could share the information we’re asking above. So that we could take a closer look and assist you further.
06-07-2023 09:33 AM
Hello everybody,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
