nest cam outdoor battery
AxelVC
i have a google nest cam intelligente outside and inside on battery
one day the battery was empty
i reloaded it but i can not turn it on again, there is a botton on the back of the cam but it doesn't work
i alrady removed it from the app google home but nothing helps
in the google home app the device is light gray it says activate device but how where can i do that?
Ebedia
Hello AxelVC,
I'm sorry to hear if your Nest camera won't turn on. To confirm, have you tried charging it with its USB charger? If so, how long did you charge it? What is the light status of your Nest camera?
Give these steps a try:
  • Hit this link for Nest camera battery charge time.
  • Since you already removed it from the Google Home app, might as well reset the actual device to the factory default then add it back to the Google Home app.
Ebedia
Hi AxelVC,
I just wanted to follow up and see if the steps above work. Let me know if you have any additional questions from here.
Ebedia
Hey AxelVC,
