10-08-2022 03:33 AM
I've installed, and for a while the nest doorbell rang my internal ( mechanical bell ) but now it doesn't, and the option to select indoor chime is greyed out. It Grey's out when I connect the wires to the terminals on the nest doorbell. Very frustrating... Any ideas please ?
10-08-2022 03:37 AM
Hi @MJCteacher
Checking in the article I found this but nothing regarding the grey out button. Did you check with Customer support on chat?
10-08-2022 07:39 AM
Other customers in this forum have mentioned that the "Indoor chime" option is grayed out and disabled when the Google Nest Doorbell (Battery) is NOT wired, which would make logical sense even though it is not documented. Is it possible you have a doorbell wiring issue? And I have seen one other customer who seemed to be reporting the same thing you are reporting (where it's functioning the opposite of how it seems like it should), except it was hard to tell from the wording in that post.
You could disconnect your doorbell and touch the doorbell wires to see if your indoor chime still works. You can also check your doorbell transformer against these requirements: https://support.google.com/googlenest/answer/9247132?hl=en
If you need to contact Google Nest Support, you need to start with this link: https://support.google.com/googlenest/gethelp
10-11-2022 08:16 PM
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate your help here, AndroiFy and MplsCustomer.
10-15-2022 07:13 AM
I appreciate the help, JT.
Archie
10-16-2022 03:45 PM
Archie
