10-28-2021 11:17 AM
I have six nest cameras in and around my home. Two of the outdoor cameras are located at my gate. They have been working great for the past 3 plus years, but recently after this most recent rain storm last week, both camera have condensation inside the lenses, resulting in poor picture quality. Again, both cameras have been in the same location and nothing has changed that would of caused this issue. Help
GA Georgeson
10-29-2021 07:53 AM
I have exactly the same problem. 3 year old camera, lens flare started 4 days ago
10-30-2021 03:05 PM
Nest has not responded with a FIX.....
11-12-2021 03:08 PM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed.
Garrett DS
11-13-2021 10:28 AM
I have the same issue, and Nest/google is not addressing any suggested fix. I have 12 cameras that, up to today, I like, but with the lack of customer support, I will change to a brand that actually gives a crap
12-09-2021 10:37 AM
12-09-2021 11:56 AM
yes Brad, since i never heard back from anyone, I STILL need help to resolve this issue.
12-09-2021 12:37 PM
I am sorry you are still awaiting assistance! I would be more than happy to look intio it for you. Can you explain to me more about your issue? What exactly do you need assistance with?
12-09-2021 01:37 PM
I have condensation on the camera lens so bad you can't see anything or anyone. I was hoping the colder weather would dry some of it up but it has not
12-14-2021 01:46 PM
Thank you for your patience with my replies! Thank you for explaining your issue a bit better! That is definitely not normal for the condensation to be present inside of the lens. Are you having this issue on all of your cameras? Or just a single or few cameras?
12-14-2021 01:47 PM
Just one camera.
01-02-2022 02:01 PM
Did this Brad douche ever reply or just keep asking the same questions that were answered with the first request?
01-02-2022 02:28 PM
He never replied, and I have now changed the camera; the old one has been sitting in a bag of rice, and the condensation is STILL there. I guess I will throw it away.
01-03-2022 10:14 AM
Typical Google crap. Resolution is to either ignore or delete. I suppose that's how your stock price triples in 20 months.
12-18-2021 06:31 PM
same here
11-12-2021 03:46 PM
Thanks I give up on Nest. The lens "fog" is slowly fading, and I will just continue using as is until I find another better brand. My nest hello is peeling. From others comments, a common problem ?
12-18-2021 06:29 PM
Same here, a normal rain and the camera is ruined
12-31-2021 04:50 PM
I'm having the same problem, the Nest Outdoor camera has condensation inside the lens, I have four of them and only one that has the issue, for what these cost and being outdoor rated really surprised that this happening and sure it won't be long before the rest have this same issue and then will no longer be visible do to the moisture blocking the site.
Todd
