12-18-2021 09:56 AM
I've had 2nd gen Chromecasts for a while now and just got a CCWGT. Over the last couple weeks (December 2021) we started noticing audio was auto leveling. We didn't change anything in our setup. Has anyone else noticed this and have a fix for it? I have noticed this on CCWGTV with digit audio to sound bar, gen 2 CC direct to TV speakers and CC Ultra hooked up to a denon reviewer with all TV and audio equipment with auto leveling disabled.
12-18-2021 10:50 AM - edited 12-18-2021 10:52 AM
First, disable auto volume leveling on your TV.
Chromecast with Google TV doesn't offer any settings for volume leveling or dynamic range compression.
I urge you to send feedback to Google via Google Home application, as I already done that and I also opened a thread about this on this community.
12-19-2021 08:14 AM - edited 12-19-2021 08:15 AM
Volume leveling is not an issue unless the audio stream (like multichannel Dolby Digital) has embedded values for dialog normalisation, thus triggering dynamic range compression algorithm.
That the reason I requested additional sound settings option to be able to manually disable dynamic range compression algorithm.
12-19-2021 07:45 AM
Thanks for the feedback. I'll submit feedback from the Home app. As for disabling auto volume, I did ensure it was disabled before posting. Auto leveling was never an issue until a few weeks ago. I haven't seen settings for it either so wasn't sure what has happened.
12-27-2021 01:24 PM
Just checking up,
Jeran
12-28-2021 02:18 PM
Hey there!
We haven't heard back from Silvermystic, and it's been a few days, so I'm locking the thread. As always, feel free to make a new thread if you have any more questions or concerns.
Thank you for your help, djtetei!
Jeran
