01-19-2023 11:54 AM
Hello I am using the Chromecast with Google TV and have a google max speaker. Couple issues
I keep loosing or getting choppy audio every 10-15 minutes of use. Also for some reason when I turn on my Google TV it does not automatically reconnect to my max speaker. I have to manually reconnect it every time
Will appreciate any help/guidance to fix the issues
Thank you
01-25-2023 09:02 AM
Hey there CL2,
Welcome to the Chromecast Community Forum! I'd be happy to help you out here, as I can imagine having to manually connect the speaker every time is pretty annoying. First, make sure your Chromecast and the speaker are both up-to-date on their firmware updates. Then, make sure you only have one speaker connected to the Chromecast with Google TV at the same time. Afterwards, keep the device within 15-20 feet from the TV.
Jeran
01-31-2023 12:30 PM
Hey there CL2,
Do you have any more questions that I can address?
Thank you,
Jeran
02-01-2023 12:38 PM
Hey CL2,
Do you have any more questions? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
