02-20-2022 09:35 AM
Chromecast remote batteries draining in 25 days - brand new Energizer alkaline AAA batteries, tested 1.58 volts on 23 Jan 2022, died on 18 Feb 2022 (25 days), tested 1.39 volts. Am using a couple of hours each evening, mostly Netflix with a dumb Sharp TV which has its own remote for volume, and removing the batteries overnight. Not using with a smartphone. 25 days seems very short. Is this normal? How long does Google say the batteries should last? I guess this is a 3rd gen Chromecast, bought in 2021. How do I check what generation it is?
02-26-2022 03:01 PM
Hi GerardGS,
Thanks for reaching out to the Google Nest Community. If your device comes with a remote, it means that you have the latest generation of Chromecast. Also for battery life, we expect 6+ months with normal use.
Please give these steps a try:
After doing the steps, please observe the behavior of your Voice Remote and keep me posted.
Jennifer
03-05-2022 12:20 PM
Hi GerardGS,
Just checking in to make sure that you saw my response. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Jennifer
03-01-2022 03:04 PM
How's it going with your Voice Remote? Did those steps help?
Jennifer
