12-02-2021 02:14 PM
Hey guys, bit of a weird problem here so wondering if anyone has experienced the same/solved it. So whenever I turn my soundbar on, the Chromecast's wifi speed drops to like 0.1MB/s and whatever I'm streaming just stops and is basically useless. But as soon as I turn the soundbar off streaming starts back up again and wifi speeds return to normal.
12-02-2021 06:10 PM
Does your soundbar have wireless functions, such as wifi, Bluetooth, etc? If so it may be transmitting , probably at max power, and causing massive interference for your chromecast. Suggestion would be to try to out some distance between the Chromecast and the soundbar if possible, or depending on your soundbar and setup you may be able to disable wifi /Bluetooth .
12-03-2021 03:50 AM - edited 12-03-2021 03:52 AM
Connect the Chromecast device via gigabit ethernet adapter and use its WiFi connection only when strictly necessary.
This way, you have a stable internet connection for your Chromecast device and can use the soundbar in all connectivity scenarios.
12-02-2021 06:10 PM
12-02-2021 07:12 PM
Make sure you switch the Chromecast to non 5ghz wifi connection.
12-02-2021 07:20 PM
Chromecast can work great on GHz ... And if the soundbar has wifi it is probably 2.4 GHz , more chances for interference on the lower band.
12-03-2021 03:52 AM
That is false. My LG soundbar uses 5G and is next to my router. 5ghz gets degraded when the soundbar is in so I have to switch
12-07-2021 01:51 PM
Just checking up,
Jeran
12-08-2021 01:59 PM
Hey there!
We haven't heard back from maclinn77, and it's been a few days, so I'm locking the thread. As always, feel free to make a new thread if you have any more questions or concerns.
Thank you for your help, everyone!
Jeran
