Dolby Vision HDR
emmamilton
When using the Chromecast with Google TV, does the TV also have to support Dolby Vision for it to work or does the dongle do all the work?
RXShorty
Hi @emmamilton
Your TV has to support Dolby Vision and HDR to get it working. It has to do with the TV panel itself.
By adding a Chromecast Google TV to a TV doesn't add Dolby Vision or HDR to any TV without support. 🙂
6 REPLIES 6
RXShorty
Hi @emmamilton
Many thanks for the speedy reply which confirms what I suspected but surprisingly couldn't find a definitive answer searching elsewhere online!
JenniferV
Hello there,
I appreciate your help here, RXShorty.
emmamilton, our Product Expert is correct. You can adjust the resolution, format, and other display settings depending on the features available on your TV. You can see this information here
Jennifer
JenniferV
Hi emmamilton,
It's us again. We want to check if you still have questions and concerns. Feel free to let us know if you do.
Jennifer
All good thanks!
JenniferV
Got it. Since you don't have any more concerns, I'll go ahead and lock this thread now. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
Jennifer
