chromecast problem
Mariarosaria
I am still waiting for the operator to let me know how to restore my chromecast as it always flashes orange, in fact the firmware of the preview program nr. 291998 has bugs, in addition I am also waiting for an answer for the problem on the GOOGLE HOME application of email notifications and no one has been heard anymore
13 REPLIES 13
JenniferV
Hi Mariarosaria,
Thanks for reaching out. Do you still have the case ID of your interaction from our support team? If yes, please provide it to us so we can have it reviewed.
Jennifer
unfortunately I don't have it, they told me that the chromecast would receive an update but to date nothing
JenniferV
Thanks for getting back to us. The Chromecast update is over the air. As long as it is connected to the Wi-Fi network, it will automatically receive it. You may try to reset the Chromecast to trigger the update. Also, I'd suggest you send feedback about this using the Google Home app. Here's how
Jennifer
it does not update, it is always to the previous version, I rebooted but nothing
JenniferV
Hello Mariarosaria,
Have you tried to send feedback about this? If you haven't yet, please try to do so. Every bit of feedback and logs on the subject helps a ton.
Jennifer
Yes done
Jeran
Hey there Mariarosaria,
Thank you for submitting feedback on that! The device logs from your submission help the engineering team track down what errors are occurring on the device, making the fix much easier. In the meantime, did you have any other questions or concerns we can address?
Jeran
so I didn't understand, what should I send you?
Jeran
Hiya Mariarosaria,
You mentioned that you submitted feedback, that's all we needed from you to send to the engineering team regarding your Chromecast issue. Nothing else is needed on your end!
Let me know if you had any more questions, we're always happy to help.
Jeran
but have you already sent everything to the technicians for checks?
Jeran
Hey Mariarosaria,
When you submit feedback and check the box labelled System logs, the feedback and logs go directly to our engineers, and they'll be able to investigate this issue further.
Let me know if you have further questions!
Jeran
hopefully this time they answer me
Jeran
Hiya Mariarosaria,
I'm glad to hear that you re-submitted that feedback, Google takes all submitted feedback seriously, and it helps them track down and resolves these issues easier. Let me know if you have any other questions, as we will be locking this thread in 24 hours.
Jeran
